Design SuiteCreating spaces with the Space tool
Tool
Workspace: Tool set
Space
Design Suite, Architect, Landmark: Space Planning
Spotlight, ConnectCAD: Add tool to workspace (see Customizing workspaces)
Spaces are path objects that have the characteristics of a building space or room, which include information such as the space name, number, finish information, and net/gross volume. The space label data tags can display not only name and number, but virtually any desired information. Space objects automatically calculate their area, volume, and perimeter, which can take into account subareas that might change a space's measurements, such as door niches, windows, and spaces with angled ceiling or floors. This data can be used to create detailed reports needed in a variety of jurisdictions. Spaces can be nested inside other space objects.
The Room Name Simple tool (in the Dims/Notes tool set of all workspaces but Landmark) creates a text label only; it does not attach room finish, area, IFC, or GSA information to a space object.
To draw a free-standing space with the Space tool, click either Rectangle or Vertex mode. If the walls are already drawn, click Picked Walls mode or Inner Boundary mode to create a space bounded by visible walls; see Editing space boundaries.
Mode
Description
Check mark
Executes the operation.
The check mark button is enabled only when Picked Walls mode is selected.
Picked Walls
Creates a space object based on a closed set of selected walls
Inner Boundary
Creates a space object in a clicked area that is bounded by visible walls
Rectangle
Draws a rectangular space object
Vertex
Draws a polyline space object; as with a polyline, select one of six types of control points for the vertices from the Tool bar
Pick Up
Picks up the attributes of a space that is clicked upon.
The properties that are transferred can be customized; see Space settings: Advanced Settings pane for details.
Apply
Transfers the space attributes that have been picked up with the Pick Up mode to a space that is clicked upon.
Press the Alt key (Windows) or the Option key (Mac) when you click to toggle between the Pick Up and Apply modes.
Polyline creation options
For Vertex mode, selects the method for drawing the object's path polyline; see Creating polylines
Space Style
Opens the Resource Selector to select a space style; double-click the resource to activate it
Preferences
Sets the default parameters that are used for each new space object; see Space settings
Creating spaces from picked walls
Mode
Tool
Workspace: Tool set
Picked Walls
Space
Architect: Space Planning and Building Shell
To create a space within a selected set of visible walls:
Click the tool.
Do one of the following:
Click Space Style on the Tool bar to select a resource from the Resource Selector.
From the Attributes palette, set the 2D attributes for the space (fill, pen, opacity, and line thickness), and then click Preferences to open the Space Preferences dialog box and specify the tool's default parameters.
The parameters can be edited later from the Object Info palette.
Click Picked Walls mode.
Click each wall that forms the wall set and then press Enter, or click the check mark button on the Tool bar. The space is created and automatically associated with its bounding walls.
Add information specific to the space.
Optionally, create a style resource from an unstyled object (see Custom plug-in object styles without catalog options).
Creating spaces from the inner boundary of walls
Mode
Tool
Workspace: Tool set
Inner Boundary
Space
Alternatively, use the Create Spaces from Walls command to create spaces from a set of enclosed walls on a specified design layer (see Creating spaces from walls).
To create a space within a closed set of visible walls:
Click the tool.
Click Inner Boundary mode.
Click in an open area of the drawing that is bounded by walls; the walls must be visible, joined together, and on layers that have the same layer scale as the space layer. The space is created and automatically associated with its bounding walls.
Drawing spaces with the Space tool
Mode
Tool
Workspace: Tool set
Rectangle
Vertex
Space
To draw a space with the Space tool:
Click the tool.
Click Rectangle mode, or click Vertex mode and then click the desired polyline creation mode; see Creating polylines.
Draw the space as follows:
For a rectangular space, click to begin the rectangle, and then click again to finish the rectangle and create the space.
For a polyline space, click to begin the polyline, and then click to set each polyline vertex. Click the start point to end the polyline and create the space.
The space is created with the attributes and settings you specified.
Adding information to spaces
After all spaces have been created, select specific spaces and add more information to them from the Object Info palette, such as a space name and room finishes. The items that are changed most frequently are available on the Shape tab. To access the full set of space properties, including detailed space area settings, click the Settings button to open the Space Settings dialog box.
Alternatively, data tags can be set up with user-entered fields, so that users can quickly and easily update data shown on the tag (such as the space name or a manual space number) by editing the tag data. See Creating data tag styles.
The properties available from the Object Info palette are determined by the Advanced Settings pane on the Space Settings dialog box. See Space settings: Advanced Settings pane for details.
Copying attributes to other spaces
Mode
Tool
Workspace: Tool set
Pick Up
Apply
Space
If several spaces need to have attributes in common, such as the same space name and room finishes, copy the attributes from an existing space and apply them to the other spaces.
To create spaces with many parameter, attributes, and information in common, it may be more efficient to create a style resource that can also be reused in other files; see Concept: Plug-in object styles.
To copy attributes to other spaces:
Click the tool and then click Preferences.
On the Space Preferences dialog box Advanced Settings pane, select the attributes to transfer between spaces from the Eyedropper Transfer Properties window (see Space settings: Advanced Settings pane for details).
Click the Pick Up mode from the Tool bar. Click the space with the attributes you want to transfer.
Click the Apply mode from the Tool bar, and click each space that should have those attributes.
Alternatively, press the Ctrl key (Windows) or the Option key (Mac) while you click to activate the Apply mode.
Space settings
